- Aug 22, 2012
- 4,114
I believe I may have a major problem with my lathe (generic 9x20)
This is the second time I have had the half nut threads wear away.
The first time it happened I hadnt had the lathe long and the problem was swarf collecting inside and preventing the nuts from fully closing.
I sorted that out by making a new lever, placing the detents further apart and adjusting the mechanism ensuring the nuts fully clamped onto the lead screw and regularly cleaning out any swarf.
I stripped and reassembled and re adjusted it this time, most of the thread had gone but I needed to finish a job so had a go.
A couple of things I checked.
The saddle travels from end to end and the lead screw doesnt move up, down, in, or out so its in alignment with the worm and tail stock end bearing and the half nuts clamp firmly to the leadscrew. I will also check out the leadscrew for straightness some time but it doesnt wobble in the tail stock end is not bolted down so I'm assuming its pretty straight.
BUT
When I engage the threading lever to clamp the half nuts to the lead screw the lead screw flexes inwards towards the bed. I ensured the remaining threads were fully engaged.
This has caused wear in the worm housing bearing at that position as well so its been going on a long time.
I have thought of placing some shims behind the worm housing to move it inwards towards the lead screw and possibly facing the tail stock end bearing down to move the lead screw inwards the amount it seems to flex.
The threads on the lead screw also appear to be very sharp on their edges and in particular where the keyway is cut and from the colour of the dust seems to be actually cutting the half nuts.
Major questions -
Where can I purchase the half nuts without the 12 to 16 weeks delivery time I'm being quoted in Australia?
Is it feasible to dress the complete thread on the lead screw to remove all the sharp edges? (or worth it)
Are the mods mentioned above worth doing?
Can anyone suggest any other things I could do? (other than purchasing a better lathe)
Thanks
BUT
Major questions -
Thanks
