935TS Quill Deflection
Jeffphillips
Mar 6, 2021
5
when putting an indicator about 1.5” down on an endmill held in a collet in the quill, I get about .001” deflection With the application of light/moderate force against the cutter. This is with the quill extended about 2” and locked.
Cuts Exhibit the same .001 deflection when measured vs what the DRO indicates they should be.
is this normal, or is there an adjustment for it?
it is almost perfectly repeatable, so relatively easy to accommodate for, but a bit annoying.
I have no experience with PM mills but my first thought would be to check the bearings for wear or proper adjustment. Also, I do 99% of my milling with the quill fully retracted and locked.
apologies, I should have been more specific, the deflection appears to be in the spindle. The position of the quill has no noticeable affect; whether it is extended 2” or not at all.
Is it the spindle or is it the head that is moving. I get about 0.0005" deflection on my full size knee mill, the 935 is about 1000 lbs less with similar Z and Y travel.
I have the PM-935 mill and have a few comments and some analysis to share. I have done extensive testing of the rigidity of this machine, including the quill deflection when fully extended. I did these tests because the 935 was not performing to the level of my RF-45 in terms of rigidity. With respect to the quill specifically, I can offer you a link to a few videos that demonstrate the quill deflection under pressure/load of my 935. Mind you these test were done on a new J-head supplied by PM under warranty (full story here). You can view those tests at this link.
Based on your description of deflection, it's difficult to know if this is related to the quill cassette being loosely fitted to the J-head casting, or if it's just the actual limited rigidity of the machine due to the size of the ram castings, or the knuckle and mounting bolt attachments.
If you want to delve into this deeper, please feel free to reach out with a DM. The 935 is a terrific junior-sized knee mill, but being of reduced weight and particularly the ram/knuckle profiles and attachment mechanisms, it is unlikely to be as rigid as something like a Wells-Index 847 or even the Acra LCM-42 that Mark (@mksj) has, nor is it as rigid as my 2001 Rong Fu 45 square column mill/drill - at least when it comes to tool deflection under load and resulting surface finishes. More details on that analysis is here.
As for the comments above about using the knee to advance the drilling operation, I cry "humbug" - your quill should be rigid enough to perform power downfeed operations with a boring head to attain tolerances under 0.001". The J-head on these machines was specifically designed to provide tight tolerance boring facilities with a power feed system on the quill in both up and down movement. Of course the resulting tolerances are related to the inherent rigidity of the Head-to-Ram-to-Column interface limits - which apply equally to elevating the knee or lowering the quill.
David Best
