- Aug 22, 2012
- 4,125
I have a lot of backlash in my cross slide lead screw so I thought I would have a go at making the delrin nut.
As I will have to dismantle the cross slide to do this I thought I might as well make a new lead screw, thicker, longer and with bearings in the front.
So, decision time.
If I make the lead screw with a 1mm thread pitch then one complete turn will advance the cross slide 1 mm.
therefore each division of the dial will be 0.02mm instead of 0.025 as it is now.
I think I will use a 10mm dia shaft.
The question is - will a 1mm thread pitch be too fine for this application.
So, decision time.
