Hi everybody,
I have just finished getting my new mill indtalled in my little shop.![4410e1edea302a56ec8c6554db5af614.jpg 4410e1edea302a56ec8c6554db5af614.jpg](https://www.hobby-machinist.com/data/attachments/154/154800-3ad07968affb31db202caa66ecfe00b5.jpg)
I apologise to most of you for using metric measures, but I live in Oslo, Norway and do everything in metric, although I can get by in inchces and stuffbif I have to![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Now before I go messing stuff up I have a few questions.
I have an er 32 collet chuck and a new set of end mills from 4 mm to 20mm diameter (HSS endmills with that hard coating that makes them look yellowish gold, TiNi ?), both 2 and 4 flute types, spiral flutes, not straight) My mill can operate from 80 to just over 2000 rpm.
It has a 1,1 kw motor ( it is also labeled 1.5 hp but that is a fair bit more than 1,1 kw so I am assuming the lower number).
Now I will be milling aluminium and mild steel mostly.
Could someone explain the basics around calculating suitable rpms for the various sizes of end mill?
I have seen a lot of info regarding chip loading and stuff, but I dont understand it all.
I would like to be able to work the numbers for myself, but I need some help with how to do that.
I would guess that the softer the metal the higher the rpm for a given diameter of end mill?
Also higher rpm for smaller endmills in the same material? This would keep the speed of the cutting edge through the material similar, which I am led to belive is a good thing.
Look forward to hearing from you all![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![4410e1edea302a56ec8c6554db5af614.jpg 4410e1edea302a56ec8c6554db5af614.jpg](https://www.hobby-machinist.com/data/attachments/150/150954-3ad07968affb31db202caa66ecfe00b5.jpg)
![4410e1edea302a56ec8c6554db5af614.jpg 4410e1edea302a56ec8c6554db5af614.jpg](https://www.hobby-machinist.com/data/attachments/151/151180-3ad07968affb31db202caa66ecfe00b5.jpg)
![4410e1edea302a56ec8c6554db5af614.jpg 4410e1edea302a56ec8c6554db5af614.jpg](https://www.hobby-machinist.com/data/attachments/151/151810-3ad07968affb31db202caa66ecfe00b5.jpg)
![4410e1edea302a56ec8c6554db5af614.jpg 4410e1edea302a56ec8c6554db5af614.jpg](https://www.hobby-machinist.com/data/attachments/153/153052-3ad07968affb31db202caa66ecfe00b5.jpg)
![4410e1edea302a56ec8c6554db5af614.jpg 4410e1edea302a56ec8c6554db5af614.jpg](https://www.hobby-machinist.com/data/attachments/153/153889-3ad07968affb31db202caa66ecfe00b5.jpg)
