- Dec 27, 2013
- 124
In a perfect world, you would make at least a GO nut that is right on nominal for that size. Mark it and keep it for next time.
A side note: is there an equivalent to external thread wires for internal threads?
Back in the day, we used OD calipers with the tips ground down to an angle of less than 60 degrees to achieve the same result.
I used one just yesterday to help out a client on site. I did not have 3/4-16 die nut,bit do have a thread file with 16tpi and it did the job and the client was happy, that's all that matters.Ah thread files, a beginner's best friend.
It was either Abomb79 or Keith Fenner (on Youtube) that showed how to use the compound to reacquire the thread. Basically, you set the compound 90º to the cross slide. ...
