[4]
A Novel Approach to Reading the Micrometer
[3]
[10] Like what you see?
T
Tom Griffin
Guest - Please Register!
This is my first request, courtesy of a member from one of the other forums where I hang out.
When I taught high school machine shop in the 70's, one of the first things I taught my students was how to read the micrometer. I used a method involving pocket change and it worked very well.
Tom
[video=youtube_share;UQHKAcQzS3Q]http://youtu.be/UQHKAcQzS3Q[/video]
Nightshift
Jan 26, 2012
58
Tom, that's the best explanation of how to read a mike that I've ever seen. Well done and thanks for sharing! Bill
T
Tom Griffin
Thanks Bill, glad you enjoyed it.
Tom
Harvey Melvin Richards
Nov 13, 2012
175
When I have an important measurement involving a micrometer or a depth gauge there are times where I cheat. I use my digital calipers to check the opening on the mike, or the extension on the depth gauge and confirm that my measurements are correct.
David S
Nov 18, 2012
1,327
Tom thank you for sharing. I work on clocks and some stuff is imperial and some stuff is metric. I recently got a metric micrometer and am having to get my head around the "new" system.
Very good video.
T
Tom Griffin
Someone mentioned the metric thing on another forum so I dusted off a metric mic of mine and found that the technique works just as well on a metric micrometer. Just use dollars for the millimeter divisions (25), half dollars for the division between them and pennies for the divisions on the thimble (50). Add them all up and place the decimal point after the millimeter value.
Tom
SE18
Feb 26, 2012
758
I thought the explanation using pennies, quarters and dollars was outstanding and I picked up on it right away, but sorry to say I got completely lost with the last explanation on the ten-thousandths and wasn't sure how to do that. I watched the video three times. I'm not too bright either, so I'm sure it was my fault. My mic, btw is exactly like the last one you showed so I'd be interested in learning that last step, even though I probably would normally not need that level of precision for what I do.
Anyway, thanks. Anything that helps newbees is right on with me!
(The other hard thing I have is figuring decimals to fractions (or visa-versa); I use Machinery's Handbook and cheat). Going from decimal to imperial even harder, using handbook.
T
Tom Griffin
You are probably over thinking it. Once you get the thousandths figured out (it sounds like you got that part worked out), if a mark is showing between the thousandth divisions on the thimble (First pic below) add .0005. If more is showing, look on the vernier scale on the barrel and see which numbered line aligns with any division on the thimble (only one will align). In the second pic below, it's the number 3 line, so add an additional .0003. So the reading shown is .4718" (.471+.0005+.0003). Make sense?
You are correct though, you'll probably never have a need for a tenth reading mic unless you have a surface grinder or a toolroom lathe, they can work to tenths.
Tom
SE18
Feb 26, 2012
758
Tom, I got it now. That's pretty weird how that's done but you explained it perfect and with photos too!
T
Tom Griffin
Great.
The concept of using a vernier scale can be a bit difficult to understand, but vernier scales were the way it was done on height gauges and calipers before the advent of digital readouts.
Tom
jamesicus
New Member
Aug 3, 2013
23
Most excellent, Tom. The best way to to teach reading a micrometer to newcomers I have encountered.
James
T
Tom Griffin
Thanks James I'm glad you enjoyed it.
I used to use that technique to teach ninth grade students and they were very receptive to it. Money is a lot easier to relate to than numbers on a tool.
Tom
core-oil
Dec 30, 2010
432
Thanks Tom,
I will use this method of teaching this subject to a friend of mine who is finding the concept of micrometers worrying He is a good guy, but never had to read mic's before
Again thanks for a simple but brilliant explanation.
T
Tom Griffin
I've been asked to do a metric version of the same technique, but haven't got around to it yet. It works the same though, just with different coins. Or are you using the inch system in machining? Whenever I watch one of Doubleboost's machining videos on Youtube, he seems to be using inch micrometers.
Tom
pineyfolks
Apr 30, 2012
1,078
Great video, makes a lot of cents :lmao:...I'll be using it to teach my grandson ASAP
T
Tom Griffin
:lmao::lmao::lmao:
KBeitz
Apr 17, 2018
475
The URL above did not work foe me.... I fixed it...
[6]
[5] [7]
