Ac to dc
Lapowers
Mar 15, 2014
8
I was wondering if anyone knows how to wire a 115 volt dc motor to ac
With a 115VDC power supply. I could build one but I don't think I could guide you through doing it. Are you interested in selling that motor?
Sounds like you need a motor controller that uses Pulse Width Modulation to feed the motor. An inexpensive solution is to utilize a 2nd hand Treadmill Motor Controller such as an MC-60. Readily available on ebay for about $35.
What is your application?
Matt
If you just want single speed the cheapest what would be with a full wave bridge rectifier. Would need to know the rating of your motor to select the appropriate rectifier.
David
The problem with just using a bridge rectifier is that you are going to generate about 160V peak DC (no load). This may not be a problem, but it is something to keep in mind. The voltages listed for AC values are "RMS" values, which is an average of the AC wave.
I have run small DC motors (a little 115VDC gear motor) with a combination of a light dimmer and a bridge rectifier. This allowed for pretty effective speed control. Those light dimmers are not rated for motor use, so I would not try them on anything over about 1/4hp.
If you do this, I would also highly recommend adding a fuse ahead of the rectifier, and putting all the bits in a box.
There are also off the shelf DC controllers that use something called "SCR control". The good ones are expensive, but they turn up as surplus periodically. These allow very nice speed control.
Unless he adds a filter capacitor he will get 115V RMS which is what the motor wants.
RMS is root-mean-square, which is the same for a sine wave AC signal and a full wave rectification of it. The average of the AC wave is zero.
I agree that he ought to get himself some sort of speed control, though. Otherwise there's no point in having a DC motor.
Look up dc speed controls on ebay..
It is true that the RMS value after the bridge will be 115V. This may not be a problem, UNLESS he trys to filter things by adding a capacitor, and that capacitor doesn't take the peaks into account (ask me how I know. Hint it's the same way I know that exploding capacitors are very loud and smell bad ;) The first time I tried this, I didn't take this into account; just trying to help others from having to air out the house.
The only reason any of this is pertinent to the OPs question of course is is if he has something on the line that can't handle that peak voltage. According to wikipedia, that is going to be about 1.4 times larger than the RMS voltage (around 160V)
I bought a south bend lathe with a 1/2hp westinghouse 115v dc motor 4.7 amp the motor was disconnected and none of the wires where marked where they go I found a rectifier in with the wires now I'm just trying to figure out how to wire everything up if worse comes to worse I have 1/2 hp ac motor I could use
