Acrylic Cubes
Fabrickator
Jan 22, 2014
577
I bought a 2" x 2" slab of cast acrylic and cut out some cubes to make some dice. I cut them out on my band saw and trued them up in the lathe. I lapped them with 400 grit and then polished them with my 10" cotton buffing wheel with tripoli compound @ 2400 rpm. They came out super clean & optical clear and throw off some cool optical illusions when you walk around them. I plan to make one a die and other I may make a turner's cube. These are straight forward, one-piece clear cubes with no lamination's (like the pics may infer).
ch2co
Grumpy Old Man
Jan 9, 2013
1,014
Very cool. Nice work. Fun with optics. But a turner's cube in plastic? Wow. Gotta see that one.
CHuck the grumpy old guy
ch2co
Grumpy Old Man
Jan 9, 2013
1,014
PS A great polishing job. You sir, are a very patient man.
modela
May 6, 2012
116
View attachment 118672 View attachment 118673
You are truly a patient person. In my business we sold and fabricated acrylics. Fabrication can drive you nuts. Gluing is even more potentially problematic. Nice Job.
Fabrickator
Jan 22, 2014
577
That's cool you can buy them, but that takes all of the fun out of making it. : ) I got a good deal on the slab for $10 as a remnant and I can get 4 more out of it. I've seen someone on the web that made a turners cube out of acrylic, so it can be done. Of course, it would be near impossible to polish inside the bores.
I bought the buffing wheels and compounds for my wood projects (bowls, vases, boxes) 20 years ago, but they've come in real handy in my metal projects. Each cube was lapped in about 5 minutes w/400 grit and polished in about 15 minutes.
SHOP TIP - I use my standing drill press for lapping. Just tape a half sheet of wet dry on the front side of the table and it works great. Standing up is more comfortable for my back than bending over a bench using a surface plate.
RJSakowski
H-M Supporter - Gold Member
Feb 1, 2015
5,095
Great job on the cubes! Your aluminum "diamond" would look great done in acrylic.
Fabrickator
Jan 22, 2014
577
That would be very cool. Cutting it would not be a problem, but lapping/polishing would be tricky. Plastic, like aluminum is so soft, it's hard to polish the facets w/o losing the delicate edges. I would have to make (and I've thought about this for a while) a lapping/polishing articulating arm jig to hold the angles, much like a lapidary wheel polisher.
Fabrickator
Jan 22, 2014
577
I've heard about it, but I haven't had any positive experiences when I've tried it. Have you?
Fabrickator
Jan 22, 2014
577
I decided to leave one clear and the other I finished as a die. The die has a cool effect of looking like there are bubbles floating inside because you can see through it.
dlane
Sep 27, 2014
3,084
Actually I use an industrial heat gun , sand smooth down to 600 , heat till it just shines over.
Takes a little practice to get a consistent finish.
mzayd3
Feb 10, 2014
366
I am always amazed at the artwork you produce. Very nicely done!
ch2co
Grumpy Old Man
Jan 9, 2013
1,014
QUOTE= The die has a cool effect of looking like there are bubbles floating inside because you can see through it.
That is a really cool optical illusion. Mighty fine work mighty fine.
AdBlock Detected
I've Disabled AdBlock
