R
Robert LaLonde
Forum Guest
Register Today
I was sitting here thinking about a tricky mold build. Well tricky for me anyway. The solution is to cut the mold, assemble it, turn the outside round, and drop it into a sleeve a few thousandths bigger to allow for venting, but limit flashing. I am pleased as punch about figuring out the solution to the problem, but that's not the only problem. I'm looking at target diameters of .997 and 1" respectively.
I don't own a reamer that big. No big deal. I could buy one and it would get here long before the job comes up on the board. I just didn't want to spend the money for one I would use one time in one hole and never use it again. They aren't cheap. Sure I pay that much for a fancy mill from time to time, but I get a lot of hours out of it, before it goes in the recycle pot.
Yeah, I suppose I could bore it on the lathe, but the sleeve has to be machined into a rectanguloid box. I also need to be pretty close on my tolerance. If I have deeper grooves inside it could flash, and if I get it to small it could seize or just not vent well. It would be kind of a pain to setup.
I'll probably 3D machine the sleeve half in each of two pieces to around 0.990 and then assemble and ream to size.
Than I thought... hmmm maybe I can borrow one from my dad. He has some old adjustable reamers. Maybe he has one that will cover the 1" range. He has a set and he offered to just give them to me. I asked him how much he paid for them and offered to pay for them since I will use it in my business. Yeah, you can give me some money if you want, but I only paid $25 for them. Never used the larger ones.
Nice. Two problems solved today. And even the solution to the solution.
