Hi All,
I tried to search for an answer but did not see anything specific.
I'm new to this so please be gentle...
I picked up a mini lathe (used) and have been playing with getting it setup and testing it out.
I noticed it was slipping occasionally and I found the belt was just loose.
I also found the teeth on the belt and pulleys wearing, maybe it's just age but I want to replace them.
I broke it down to get to the belt and tighten it up... but the adjustment system is not logical, although it seems like it is at first glance.
I started by loosening the adjustment screws and trying to move the motor down to add some tension per the instructions.
This got the tension right, but then as I tighten the screws the motor seems to twist and noses up/down causing belt misalignment.
At one point I thought i had it dead on, but then when I went to tighten the 2 strews that just push against the motor (this makes sense if you have one), everything got jacked up.
Is there a correct way to do this and stop the motor from twisting?
Or am I over thinking the belt alignment and I just need to get the tension right and the cover will keep the belt in place?
...I do have replacement belts and pulleys but want to make sure I have the procedure right before I put them on as I do not want to destroy the new parts!
thanks
thanks
