Here are some pictures as promised. Thinking ahead on this project, has brought up another question. When one mounts a wobbler cylinder, it has two ports in it that allow for the entry and exit of the steam from the cylinder. These ports, swing in an arch, and coincide with ports in the main frame. I am trying to determine the placement of the ports in the frame. It seems that steam entry, for a power stroke, should be just before TDC [or BDC] Is there a place that relates to the position of the crank, that the ports should be aligned? To say it another way. Say I have the cylinders attached to a frame, ports in the cylinders but none in the frame. Crank and journals installed. Now by rotating the crank by hand, I can determine the arch produced by the cylinder ports. However, I am unsure where, along that arch, the ports in the frame should be placed. It would seem that if it were at the extreme ends, that the piston would be midway of its travel. So hopefully someone here, understands what I am asking, and has some insight. Now off to find some graphite packing yarn. Thanks
