- Sep 19, 2012
- 3,063
I finally had a free minute to test the air tank. I used a 4 ton porta power I got at a garage sale for $30. I filled it with water and dishsoap, then pushed it up to 210 psi with the porta power.
This weekend it will get blasted and painted with Majic tractor paint form TSC.
A question - the paint is an enamel, that will be reduced to spray with a catalyst added. It will be on a non mobile tank that has a small shed over it, so not a lot of weather.
It will be applied on a sand blasted surface.
Do I need to prime the steel first, or can I apply directly to the steel?
Sent from somwhere in east Texas by Jake!
