- Aug 19, 2013
- 764
I'll grant that the method of expressing the dimensions in the fit chart is a little awkward. It does not follow normal machining "lingo", but the information is clearly expressed and accurate. I've been at this a while, and to me it makes perfect sense. However, if I needed to use this type of information on a regular basis, or had employees who used it, I would probably "translate" this chart into something more people are accustomed to seeing.
My training for specifying tolerances or fit on drawings has been to use limit dimensions following a specified "target" dimension. These are shown as a fraction with a plus sign on the numerator & a minus sign on the denominator for a hole and the reverse for a rod or shaft. This gives a range of acceptable finished sizes between components. My Autocad Inventor Light provides for this as well as alternate methods to specify fit dimensions.
