- Jul 22, 2013
- 122
I have been searching for a pump unit for my Boyar Schultz surface grinder. It didn't have the pump unit when I bought it even though it has hydraulic capabilities. Finding the proper used one is tricky since they usually don't have specs. I am looking at new ones, but nothing off the shelf is an exact fit. Custom build is way too expensive, more than I paid for the grinder.
I need about 1 GPM at under 500 psi. I have found 1/2 HP units at the right flow rate, but the pressure relief is usually too high. Can I replace the relief valve with either an adjustable one or a lower pressure one to make it work? How alterable is an off the shelf unit?
I was looking at something like this:
Sent from my Pixel 4a using Tapatalk
NorTrac AC Power Unit with Electric Motor - 115/230V, 3.2-Gal. Reservoir Tank, Model# YBZ5-F2.1E8G2/LKCBT1
www.acetools-supplies.com
