- Jan 28, 2022
- 854
Hi, try this shop Mesatool.com in Eagle Point Or. Jim Watson 541 890 1021 I have been using there bars with inserts for many years with no surprises. Lefts, rights, short, long, 3/4", 1/2" and more. Priced right.
It's a 3" boring head. What you describe is what I wanted to do initially. <Get Smart> I was THIS close</>What size boring head is it? You can always use the side hole on the head. Put a left hand lathe tool in it and bore away.
Just wait till I figure out how to use this rotary table.Hmmmm....... Those plates look somewhat familiar......
I'm using the bars that came with the head.OK, I have to ask the obvious question. Just because I know someone that did it the first time using a boring head.
Were you turning it right way? Using a lathe boring bar requires that the the tool rotate in the opposite direction from what you are used to. It can be hard to overcome the muscle memory turning it on in the wrong direction.
