- Sep 27, 2014
- 3,123
Hi all, been needing a way to mill lots of shell caseings for bottle openers , second caseing from left ,one at a time took to long and worried about ware and tare on my supermax mill. So I made these hopeing to use them in a screw on chuck drill press and a x y slide vice with power feed " rigid 18v cordless drill " I have tried them on the mill and they hold the caseings good, tight , rigid . The 50bmg fixture I didn't have a taper Reemer so I bedded the taper in with JB weld and brown paper, the plates sandwich the caseings when snugged up. The 30cal fixture is adjustable for angles , it will hold any 30/06 based caseings , with a adj stop .
The 50 cal fixture still needs the angled plate bolted to the back plate to hold in vice
Thanks for looking
Thanks for looking
