- Jul 28, 2017
- 2,406
This question was prompted by a project to replace my 7x12's top slide with a much more rigid riser block. I had resigned myself to needing to swap it out with the top slide when I was doing a single-point threading job, but a recent build thread about the ELS got me thinking. What are the procedural details involved when cutting threads with an ELS?
Background: In all-manual threading the usual approach is to rotate the top slide so it is at a 29.5 degree angle relative to the cross slide, but there also is an approach which reproduces the 29.5 degree tool trajectory using orthogonal movements. In this scheme, the top slide is oriented so its motion is parallel to the long axis of the work (parallel to the carriage movement). To cut threads the cross slide is advanced "X" amount and the top slide is advanced by an amount equaling tan(29.5)*X, or .5658*X. The advantage of this method is that the cross slide directly indicates the thread depth.
So if the lead screw is decoupled from the spindle (in an ELS setup), it should be possible to just use the cross slide and ELS to cut threads using the above-mentioned method. Each threading pass would simply jog the LS by .5658*(cross slide displacement) prior to starting the cutting pass. No compound needed, so if I build an ELS I could, theoretically, permanently lose the top slide. Hence my question regarding the typical process used to cut threads on an ELS equipped machine.
