I need to make two angular grooves across from each other on a round tube. Think of a helical gear or square tooth thread, very course, maybe 2-3 threads per inch. The grooves are at the end of the tube and only about 3/8-1/2" long. I tried to draw a sketch but it got too confusing. I am making a very tiny hand impact driver for itsy bitsy screws. They make large ones that I have for 3/8 square drive sockets and bits.
The tube size is about 1/2 " with a 1/4" hole. Need two grooves about 1/8" wide by about 1/2" long at an angle of around 45 degrees. The grooves need to be perpendicular to the center of the tube, so just milling a slot at an angle won't do. I would need to slowly feed in and turn at the same time. Think of a rifle land that goes through to the outside of the barrel.
The only way I can think to do this is to set the lathe for 5 threads (that is the lowest I go) and hand turn the chuck for a partial rotation over and over again. Then index 180 degrees and do the same to the other side. I don't have a helical setup like the You tube guys have. I have a rotary table and spin indexer. A jig setup that advance and rotates would work. Just haven't figured out how to build one.
