A buddy of mine bought this fixture-tool with the hopes of using it for a ball turning fixture. It has some funky adjustments on it and he's not really sure what they are for. As much as I hate to say, I don't know either!
Anyways open for thoughts for what this original fixture was used for?
It definately looks like a wheel dresser. If it is a wheel dresser won't the turning radius moving with the axis keep it from being any good as a radius turner? You will have to adjust the radius with the tool bit overhang. Or am I not thinking this all through correctly?
I would not use it as it is. But I dont think it would be hard to make a tool holder that could be mounted on that arm. It seems the arm is off set from the pivot so you could make the holder to sit right over the pivot, and adjust in and out
