[4]
Another threading help question...
[3]
[10] Like what you see?
cdhknives
Apr 12, 2013
435
Likes
90
#1
I am getting a chatter pattern in my internal threads. This is a brand new threading bar:
http://www.precisionmatthews.com/shop/12-internalexternal-threading-tool-set/
The threads have the classic chatter pattern, constant wavy pattern in the sides of the threads. 2024-t3 aluminum tube. Internal 28 tpi threads. I notice the support under the threading insert appears to be rubbing. Maybe it is oversize and needs to be ground down a bit? I have tried tap magic for aluminum and dark threading oil for cutting oils. I have sped up and slowed down. I have adjusted height. I have put a steady rest right at the end of my tube to support it. I'm out of ideas...suggestions? 20180526_171306.jpg
BtoVin83
Active Member
Aug 30, 2017
189
Likes
180
#2
what's the diameter of the threads? on small diameters the nose of the bar gets in the way
mikey
Dec 20, 2012
4,634
Likes
5,028
#3
Are you boring from the inside out with the tool in the back side of the part? I assume so; otherwise the tool is mounted upside down. If boring from the rear, tool height needs to be about 0.005 -0.010" below center height to handle tangential cutting forces. Depth of cut needs to be at least 1/2 the nose radius to reduce chatter. Might try messing with these things and see how it goes.
cdhknives
Apr 12, 2013
435
Likes
90
#4
Yes, I cut inside threads upside down so the muscle memory works the same way as outside threads.
It also pushed REALLY hard when I try to wallow out a relief groove before threading. I assume that is the support under the insert making contact.
I have tried raising and lowering the bit off the centerline and that doesn't seem to change anything.
ID is about .85" Supposedly this kit is good down to 1/2" but I am starting to doubt that. My hand ground (from a 3/8" square HSS blank) inside threading tool never had this problem.
mikey
Dec 20, 2012
4,634
Likes
5,028
#5
Did I understand correctly that you used the threading insert to cut a relief groove? If so, maybe not the right tool for that. Did you use the same insert to try to thread after forcing the groove? If so, the tip may not be very sharp anymore. Hard to know what's going on but threading in aluminum is usually pretty simple.
A 1/2" steel boring bar will easily do a 0.850" ID provided the bore is less than 2" deep.
benmychree
John York
Jun 7, 2013
2,737
Likes
1,982
#6
Certainly no need to use carbide tools to thread aluminum. I use Bokum HSS tools for threading like that, the are form relieved, so you only sharpen them on top.
BtoVin83
Active Member
Aug 30, 2017
189
Likes
180
#7
If I'm reading this correctly that's 3/8 ic insert, no way will it do a 1/2 hole. At .85 it's probably pretty tight. I've had to rotate the bar to gain end clearance which makes it even more negative rake on the insert. Given enough room that bar should make nice threads.
cdhknives
Apr 12, 2013
435
Likes
90
#8
The inserts are marked 16NRAG60
cdhknives
Apr 12, 2013
435
Likes
90
#9
I bought the set because my home ground HSS tools keep getting aluminum buildup sticking to the tip. I was hoping the coated tools would stop this. All in all the HSS problems are much less at this point...
Janderso
Jeff Anderson
H-M Platinum Supporter ($50)
Mar 26, 2018
1,037
Likes
657
#10
Watching with interest, I have never cut internal threads on aluminum, I was considering a similar cutting method.
Let us know what ended up solving the chatter.
mcostello
Dec 29, 2013
388
Likes
181
#11
If You ever suspect a tool is rubbing and cannot see it, just coat the tool with a permanent marker or layout dye. Makes something seen that is hard to see.
markba633csi
Apr 30, 2015
3,052
Likes
1,579
#12
Yes put some Dykem on and see where it rubs
westsailpat
Feb 14, 2016
619
Likes
373
#13
It might be possible to adjust the tool off center in this case down , to get clearance or grind the bar .
Silverbullet
Gold
May 4, 2015
3,419
Likes
1,673
#14
Do you do a spring cut when close to size. It does sound like clearance issues. Do you have problems when cutting external threads. If not that helps rule out some of the rigidity problems , with internal threads rigidity is a cause , the bar flexes and skips the cut. Chatter...
Bob Korves
Jul 2, 2014
6,051
Likes
6,377
#15
Negative rake for the tool mounting will help the clearance and the chatter. Aluminum cuts very easily, and the pics show little stickout of the bar from the tool holder. I suspect that rubbing is the issue, sometimes rubbing sounds like chatter, deal with that before changing anything else. TiN Coated inserts are not usually recommended for aluminum because of metal sticking. Unless you are threading at high speed, you should not have welding issues with that setup. Personally, I would use a boring bar with a HSS tool for that job, sharp and with plenty of rake, clearance, and relief.
cdhknives
Apr 12, 2013
435
Likes
90
#16
External threads are good...not great...with my ground HSS bits. There are occasional tear outs but nothing like the regular wave pattern I see on these internal cuts. I put that down to the aluminum sticking issue. I have not run the external threading bar that came with this set yet. I do run multiple spring passes, and by the second or third (outside threads) I get foil thin strips coming off...literally feathery cuts. I take that to mean my tools are adequately sharp.:D 17-4PH outside threads are perfect.
cdhknives
Apr 12, 2013
435
Likes
90
#17
Hopefully tomorrow I'll get more machine time...tending the pit doesn't leave much time to make chips.:cool:
derf
Brass
Oct 3, 2015
695
Likes
803
#18
You need to learn how to cheat. Fine threads like that in aluminum are easy to do without the aggravation you are facing. Instead of using a single point threading tool, use a tap, in this case a 1/2-28. Set the tap up in the tool holder just like the boring bar, making sure it is true with the spindle, and the cutting edge is on center. You should be able to chase that size in 2-3 passes.
Mark the tap with a sharpie where it has went full depth. Once you hit that mark, crank the cross feed in and disengage the half nut.
Guyton
Newbie
May 20, 2018
7
Likes
3
#19
One thing often overlooked it the tool length. I always keep the tool 'short' don't matter what operation I'm doing and diameter the boring bar, internal threading tool is. Also, relieving the insert helps, just as grinding/forming HS blank. Good Luck.
[6]
[5] [7]
