[4]
Another Tool Grinder
[3]
[10] Like what you see?
Billh50
Jan 26, 2015
1,922
Well my get up and go got up and went this morning. So been sitting here drawing a drill and end mill sharpener. Since I only take light cuts because I use a drill press as a mill. I decided to make a simple easy to build grinder that will sharpen 4 facet drills and the bottom of end mills. This is what I have so far.
stupoty
Dec 2, 2012
1,191
Is that an air bearing the wheels mounted on? Ahhh sorry couldn't help the pun.
Looks nice, is it going to be a manual side to side or a lever operated thingy? By the look of it very little more would be needed to do the sides of the end mills too.
I recently made an improved table for lathe tool grinding and I keep trying to imagine a relatively simple drill and end mill sharpener. I'm putting it off for the moment so I can make some things that arn't tooling :)
Stuart
[5] [7]
