- Feb 8, 2014
- 11,144
The manual lever won't move at all. I can rotate the hand wheel, but the lever will not budge.
Once the quill feed is disengaged, the quill is moved by the manual lever on the right using a simple rack and pinion, just like a drill press. Not a heck of a lot to go wrong in that system. I have seen the quill lock ''shoes'' get stuck. Loosening the quill lock and tapping on the end of the lock might break them loose, or unscrew the quill lock and remove the shoes and clean up. If the quill power feed is disengaged and the lock is released, then the only real possibility is that the quill is stuck in the bore, this is normally due to lack of lubrication and can be fixed by cleaning and oiling. The quill feed can be positively disengaged by removing the cap on the left side of the head, don't lose the springs in there.
If the price is right, this would not be a show stopper for me, but a great negotiating point.
