Looks a lot like what I used to use to shut off water sevices. The two pieces will snap together locking. There should be a about 1/8 inch hole in the cap that a special tool will unlock the cap off the stud. This would fit in a corporation stop valve that had ears on the valve stem and body that had a hole in them that the lock would fit ,this prohibiting the valve from being opened
