Anyone use this tool post grinder?
Janderso
Jeff Anderson
H-M Platinum Supporter
Mar 26, 2018
8,643
An 8x12x2" aluminum rectangle from Online Metals costs over $200....
The item that Jeff is looking at is only 1" thick. A 1x8x12 from Midwest Metal Supply is $80. Depending on the size of the router, those dimensions may change.
Edit: Look at the seller's ratings. He states that the router mounting hole is left unfinished in order to accommodate your router. So, unless your router happens to fit, you still need to do some machining.
I was thinking it included the grinder.
Asleep at the wheel :)
I would second the motion of manufacturing one, but from reclaimed materials
I have some spare material i could donate to the project, if you’d like it
