Hi All,
I'm thinking about a hobby project for which I want to turn a small capstan drum to fit on a shaft. I worked up a conceptual model (drawing attached) with function but not machinability in mind and have since been trying to think through how it could actually be turned. I think I see a couple challenges to actually making this design:
Totally open to changing the design to make it easier to machine, e.g. making the end "flange" a separate part that gets welded/screwed to the main body or...
Would appreciate if anyone has any thoughts on this--thanks for reading!
Mike
1. My first thought was this seems similar to a pulley, and the standard way I see for turning pulleys is to drill/bore out the center bore, then mount the part on a mandrel and turn the OD features. But seems a tapered or other mandrel wouldn't provide good support for a piece this long, especially considering the center bore is only about half of the part length.
I think mounting this in a chuck without tail support would probably work, though it would require 2 setups (drill/bore the shaft bore and OD in one setup, then flip and bore out the cavity). Securing it for the second setup could be a little tricky, but maybe this is still the best way?
2. Tool/tool holder clearance when turning the external recess between the "spool ends." I imagine I would use several partial depth cuts with a parting tool to make a starting "kerf" at one end to avoid plunging the turning tool, but seems the angle of the tool/holder required for turning to the far shoulder could interfere with the part at the start of the cut.
Mike
