Apron filling w/coolant
Scott-ak
Nov 14, 2020
38
1440GT Apron fills with coolant :( Anyone else having this problem?
drained about 1/2 qt of coolant out of the apron today. Surprised that this is not more common. Turns out the top of the apron, under the cross side is wide open but I think some comes in thru the splines of the power feed lever. They act like a funnel that feed fluid directly into the apron.
Precision Matthews response "You could probably rig up some type of shield or gutter setup..."
There's a lot I'd like to say about this but I'll just say this is not the kind of service/support I expected for a product that cost 12 grand.
Ummmm yeah. That is not a great response at all.
At least he didn't try to sell you a drain cock to drill, tap, and install in the bottom of the apron. Good on Matt for calling out the root cause.
@Scott-ak
Ugly! Were you using flood cooling?
Dave L.
I assume they watch this forum. Maybe they'll send a pattern for the recommended shield.
John
