Re: Are you a bit "flat" because your flat belts need replacing? try this.
Good result! Several of the SB owners in the yahoo SB group have been cutting the belts and splicing with fine wire using the wire in grooves so the wire does not touch the belt. They report excellent results, very good grip, long wear and smooth operation. Joe
