- Dec 25, 2011
- 10,514
Rich,
Unless you make it out of cast iron, a pulley made from a cast blank (aluminum) will not be nearly as strong as one made from wrought stock.
Jon,
Look more carefully at the section views of the cast iron pulleys from Leeson. The face opposite the hub is not flat on any of the three types. And on the larger PD ones, neither face is flat. So that wouldn't work very well.
Jon,
