- Aug 29, 2019
- 586
I have my McLane mill up and running with the Fugi Mini Series VFD. I am using a simple toggle switch for the FWD -OFF-REV It all works fine wired into control terminals of the VFD. I want to use the original Kannie Rotary switch that came with the mill to do the simple task the toggle switch is doing. The switch is for a 3 phase High and low speed motor so it Has Hi FWD Low FWD High REV Low REV 3 positions for OFF. I have went the route of trying to use an ohm meter to find a common and a FWD and a REV. I'm about ready to throw in the towel and just use the simple Toggle switch unless someone can throw me a bone on how these rotary cam switches work. This switch has 24 terminals with a hand full of jumpers I removed trying to find a simple FWD-OFF_REV, Thanks in advance. Here are a couple of just general pictures of the switch.
