Several years ago I bought an 8" 3 jaw chuck and turned a back plate for it. My first experience with cast iron. It seemed to fit snug but there was runout. I attributed that to the chuck not my poor attack on the cast iron. I've been on a campaign to get my tools improved. I just finished aligning the head stock on my lathe. This morning I did a series of tests and concluded it was as good as I was likely to get. I took the back plate off the chuck. D1-4 spindle. Put my Mitutoyo dial test indicator on it. Not good! I needed to take a shave on it. Tried HSS, total failure. Got out a tool with a CCMT insert, dull. Turned the insert around, much better. I turned the back plate a little thinner to get a new ledge to fit the chuck to. Each time I got to the new ledge there was resistance to cutting and then the tool would jump forward and chips would fly. Not a good way to approach and exact fit. I sharpened a HSS tool on the tool & cutter grinder. Gave that a try, no go, trashed the edge instantly. Back to the inserted tool and jumps. I got lucky and got a very tight fit. Many trials.
Time to test the results. I put a piece of 1 1/2" aluminum in the chuck and turned it smooth. Turned it around in the chuck and using the same tool position turned up to the other cut. Much to my surprise an near perfect mach. That chuck is better than I thought. Once again luck trumped talent.
