Looking for thoughts on this repair that I am in process of.
I have a Carolina HV-20bandsaw that needs repair. The shaft on the "freewheeling" wheel has been worn out. So easy enough fix, so it seems.
Simply make a copy of the original a simple plate with a 3/4" shaft poked through a plate and welded on 1 side. Then a few holes for the bolts and a couple for "adjustments" and Bobs your uncle.
Trouble is that the shaft has to be square in at least the opposite direction from where the adjustment bolts are. OEM has 2 one on each side of the shaft.
I'll call them in the horizontal position relating to the shaft. Nothing in the vertical as related to the shaft. Same as my other smaller bandsaw, so I assume that it is typical setup. Simply adjust the tip of the wheel to set the bandsaw blade so that it tracks.
So I'm concerned that after I press fit and weld the shaft it will not be as perfect as the OEM. Basically I'd guess that they have a way to keep the shaft in better square than I do for this one off repair. So I first thought that the better way would be a circle around the shaft with 3 adjustment screws. That seems like it would be a better way to control the shaft. But then I kept thinking about it and now wonder if I would be better to go ahead and do 4 adjusters. 2 in horizontal as OEM and 2 in vertical to compensate for my construction.
Thoughts?
Thoughts?
