Word of warning on chinesium blades. I got two, they were made of good bimetal stock, no complaints about the bulk material. The workmanship on the join was inexcusable, the welds were crooked and made my saw do the jitterbug, flexing the whole frame as the back side of the blade was shorter than the cutting edge. I removed them before they ruined my saw. Now I have to cut and re-weld them, something I'm not too keen about doing unless one actually breaks. Never expected chinese band saw blades to come as a kit, but lo and behold. And band saw welders used to cost $50 on ebay before the pandemic, just look at what they cost now! I didn't know they had a half ounce of gold inside, but apparently they do.
I have the Harbor Freight "equivalent"; I'm curious what you think of the 4-wheel system for moving the saw. My HF has two wheels at the motor end, foot pads on the opposite and a pick-up handle to move it like a hand truck. With the saw down, I'm guessing it's a good 40 lbs. lift to get it off the pads to wheel it around. Lifting the saw to the vertical position puts it at a good balance point, just a few pounds to lift it. I've had putting wheels at the handle end on my "list of good intentions" (the base has the holes for the through-axle there) for years though I'm curious how it steers. It would seem that 4 fixed wheels would want to go straight and not turn without dragging the front wheels. I was thinking of swiveling casters instead.Precision Matthew's PM712G.
Maybe add some RV antifreeze to your coolant? That is what I have in my tig torch water cooler.I also have to figure out how to keep it from freezing
