• PHISHING SCAM attempt TARGETING HOBBY-MACHINIST members. It has been brought to our attention that a pop-up survey is soliciting userfeedback from H-M members. In exchange for survey information, the user is given an opportunity to win a prize if they pay for shipping charges. This is NOT a Hobby Machinist program, survey or contest. DO NOT click through the links. Close your browser immediately and restart your computer. Clear cookies, cache and log back into Hobby Machinist. Again, this is NOT a Hobby Machinist contest or survey - IT IS a PHISHING SCAM attempt to get your credit card information.To close this notification, click the "X" in the top right corner of this box.
Battery for a vintage VOM
hman
H-M Platinum Supporter
Feb 17, 2013
2,737
Well, ya see, I've had this-here vintage Hewlett-Packard 427A volt-ohmmeter for quite some time.
Had it stored away for a few years, finally unearthed it a couple weeks ago. Unfortunately, the battery (an Eveready 763, 22.5 volts) had died of old age (originally installed in 1999). So I went searching. Several sellers on Amazon and eBay must have thought the battery chemistry was platinum-iridium or something, judging by the prices they wanted. Among the lowest prices was one on eBay for a bit under $70 ... sold by Lowes, of all places. Gritted my teeth and placed the order.
When the "Exell" battery arrived, I was taken aback by the weight - about half that of the old Eveready! How could such a lightweight have anywhere near the milliamp hours capacity of the original?
It seemed far from right. I didn't even try connecting it ... figured it would be easier to return if still in the original shrink wrap. Luckily, the local Lowes store was willing to handle the return.
So what to do? AHA!!! I did a bit of figgering and tried dividing 22.5 by 1.5. Got 15. Stacked up 15 AA cells, and found they would easily fit within the same volume as the 763 battery. Luckily, I'd not discarded the old 763. Cut open the cardboard "wrapper" and removed the cell stacks - three parallel stacks of 15 chicklet-sized cells.
I soldered the AA cells together in series, wrapped them with electrical tape, re-connected and re-sealed them in the original battery wrapper, and checked the voltage - right on.
Loaded the "refurbished" battery in the meter, and by golly, it's happy!
I now have a very good mirrored scale analog meter. True, even with the mirrored scale it doesn't give as many decimals of precision as a digital meter. But nothing beats an analog meter for time-varying signals! Furthermore, I have a nice, inexpensive source of replacement batteries! Assuming 50¢ a cell, that's just $7.50 ... instead of $70.00 for a "new" battery!
RJSakowski
H-M Supporter - Gold Member
Feb 1, 2015
5,175
I had a similar experience with a Triplett VOM that I acquired recently. The battery for the high resistance scale was still available at but great cost. The battery was a NEDA 210, 30 volts, 180 mah, and 16 x 26 x 65mm.
We have several appliances that use CR2032 lithium batteries that crap out when the voltage drops to about 2.8 volts. I made a carrier from a piece of PVC tubing and loaded it with a dozen used CR2032 batteries. Some button contacts on the ends and I had a 30 volt battery at essentially no cost. At 23mm, the new battery fit neatly within the small allotted space.
Should I run out of used batteries, the cost of ten fresh CR2032's is still only about a fifth of the cost of an OEM replacement battery. Lithium batteries are compact enough that they make a good choice for a substitute for some of the more exotic batteries.
KMoffett
Jan 18, 2013
472
Batteries are a pain...but there are ways around as you've done.
My daughter had a battery (one D-cell) chiming clock that ate batteries. So, we made a substitute out of a PVC pipe, a 5V wall wart, and an LM317 voltage regulator. Attached
I found a niced 3/8" craftsman rechargeable drill in our company's junk box. No battery and no charger. So I turned it into a "corded" drill with a discarded computer monitor power supply brick. Attached
hman
Feb 17, 2013
2,737
Nice, make the next one out of rechargeable batteries and you'll never have to worry about it again :encourage:
John
Thanks, John! I've actually started replacing single-use cells with Eneloop type rechargeables, and do have a bunch of AA and AAA cells on hand. I'd seriously considered using them for the meter. What kept me from doing so was the need to wire the 15 cells in series. Soldering was the only way I could come up with to do the job, so rechgarging would have meant unsoldering and later resoldering the whole pile :(
Nice save John- I wonder why HP didn't just provide a 15-cell holder- Maybe some sort of sweetheart deal with Eveready?;)
Thanks, Mark! My guess is that "back in the day" there was a goodly number of pretty popular high voltage battery packs ... "B" batteries for portable radios, etc. So HP just designed around a useful size.
And of course, not all cell stack batteries are amenable to this trick. During graduate school, one of the labs I worked at was using a 300 volt "bias" battery as a super low noise DC power supply. That one would have required 200 flashlight cells for a substitute! PS - learned something the day I had to replace the battery with a fresh one: a battery has no "off" switch, and 300 volts HURTS!
Likewise, a great save! Those CR cells pack a lot of volts into a small space.
Both great saves! Did your daughter participate in the build?
RJSakowski
Feb 1, 2015
5,175
Another strategy for reclaiming old cordless power tools is connect to a newer style battery via a cord. It seems that there is no common style for battery packs among manufacturers or even for a given manufacturer over the years. I have used the connectors from a defunct battery for a cordless tool to make a plug for the tool. With a cable attached and the other end connected to a rechargeable battery from a more current tool and the battery either hooked on my belt, I had a usable semi-cordless tool again.
ttabbal
Jun 12, 2017
1,286
You can easily charge series nimh packs. It's not as healthy for them as a balance charger would be, but it's possible. They are far more forgiving than lithium. 15 cells though, ugh.
hman
Feb 17, 2013
2,737
Good idea to use part of a battery pack as a plug. But durn! Don't ya just hate the proliferation of styles?!?!? Like a lot of other folks, I've made an "executive decision" to go with just two brands of battery tools. Got rid of several others that were yet another style.
Battery and charger technology is getting pretty wild out there. I've seen a lot of battery packs with extra contacts (temperature overload and/or monitoring individual cell voltages???). The Eneloop charger I have will take any number (up to 4) AA or AAA cells, in any combination, but won't do series. For all I know, it may well have 4 separate charging circuits. I'm not much of an electronics whiz, so I haven't tried delving into modern chargers.
Ulma Doctor
Infinitely Curious
Feb 2, 2013
1,277
nice save hman!
i like the other way of skinnin' cats when the alternative is ridiculously expensive.
i wasgunna' suggest using a 115vac transformer with a 24vac secondary.
if you add a bridge rectifier, the result would be a right about 22vdc
if you ever wanted to go that route
Bi11Hudson
Artificer00
Feb 13, 2017
637
Battery "form factors" have been wild until relatively recently. They come from early builders of vacuum tube radios. And model airplane builders. And any number of specialty applications. The recent "standardization" is a God send to me. Recent being since 1967 or so. In those days, odd voltages were profligate, and that on a good day.
The point I came onboard to make has to do with a, I think Triplett, multimeter that dates back to a friend's father working in the shipyards in the '40s. It uses a solid "brick" rated at 4.5 volts for the resistance scale. I replaced that with a "D" cell carrier with three cells. It works fine now, has for twenty years or better.
Also have a fiber optics "OTDR", basically an archaic XT with a ram disk. Hard disks in those days were pretty big, 13 inches or so deep. It also has a three cell keep alive battery, that gets changed whenever I happen to think about it.
Dry cells, carbon-zinc cells, have been around since the git-go of radio. Even the current 9 volt transistor battery is 6 each 1.5 volt dry cells bonded together inside the can. You just made a larger version. Keep up the thinking.
whitmore
Mar 3, 2017
477
Had it stored away for a few years, finally unearthed it a couple weeks ago. Unfortunately, the battery (an Eveready 763, 22.5 volts) had died of old age (originally installed in 1999)....
So what to do? AHA!!! I did a bit of figgering and tried dividing 22.5 by 1.5. Got 15. Stacked up 15 AA cells, and ...[Success! ]
A possibly easier route would be to divide 22..5 by 3.6; six lithium cells would work, and
they're available pre-wired for easy connection <https://www.digikey.com/product-detail/en/tadiran-batteries/TL-4902-P/439-1060-ND/1949333>
Downunder Bob
Staff member
H-M Lifetime Diamond Member
May 16, 2016
1,503
Always a new way to stick the pig or skin the cat. Eneloop batteries are my fave, you could always make a holder out of plastic tubing so they don't have to be soldered that way easy to take apart and recharge,.
markba633csi
Apr 30, 2015
4,684
I have/had a boy's book about electrical projects you could build. One of the last ones was a Geiger counter. Parts list:
1- 300 volt Geiger tube
3-300 volt batteries
1- pair of headphones
1- capacitor
1-resistor
Sounds real safe doesn't it? As if you can just pick up this stuff at Radio Shack-- Book was written in the 50s
Mark
Superburban
Jan 2, 2016
1,330
After messing up a VOM, by having the batteries, I have been only using the ultimate lithium, AA, and AAA batteries. They do not cost that much extra, but do claim to last longer, and that they will never leak. I did a similar thing, using 3AA batteries in a holder, to replace a BA-31 4.5 volt battery. Actually 3 holders, and 9 batteries, as the meter takes 3 BA-31's. Here is a pic of the BA-31's, the 3AA holders are about3/4'a the size of the BA-31. The missing battery, is a BA-30, or standard D cell. I would like to find some lithium D cells.
hman
Feb 17, 2013
2,737
Thanks to all of you for your responses!
nice save hman!
Thanks! I didn't really consider a homebrew 115VAC power supply ... mainly because I'd have to work really hard at suppressing ripple. I suppose I could have "adjusted" a commercial 24VDC supply to output 22.5, maybe even run the meter with 24. But the battery substitution worked well, with little extra effort.
Durn! I'd forgotten all about those 9 volt batteries when I was describing the innards of the 22.5V. I guess the 9V is the last stacked-cell "dinosaur" still in existence. Good save on the 4.5V battery!
Hmmmm ... wasn't aware of that size cell. 1.2Ah is pretty good, too. Cost would have been a bit higher than the AA alkalines, but wiring would definitely have been easier. Thanks for the link!
As I'd mentioned in my post, I like the Eneloops, too. Unfortunately, I couldn't think of a way to make a 15 cell holder that wouldn't have taken up far too much space.
1- capacitor
1-resistor
Mark
OUCH!
Another nice save! Yup, it would be nice if there were a lithium D cell ... my best guess is that D cells are not popular enough any more to justify the R&D and manufacturing investment. Think of how few devices are sold any more that use Ds. Shucks ... they may soon be on the path to extinction :(
Superburban
Jan 2, 2016
1,330
Did not think of this until reading your post. Somewhere I saw D & C cell shells that you put a AA battery into. Will have to look, maybe it was Ebay, or amazon.
hman
Feb 17, 2013
2,737
Yeee-haaaa! I recall seeing that kind of thing years and years ago, back before AA cells went alkaline and had miniscule capacity. Kinda reminded me of a [insert your favorite stereotype]'s bankroll ... a thick roll of one dollar bills, with a 20 wrapped around the outside for "flash."
Given the very light weight of the Exell battery I got, I was wondering if they'd done something similar with it. But I didn't want to take it apart and look. It would have made the thing un-returnable. Gotta wonder, though ...
Superburban
Jan 2, 2016
1,330
If not AA's, it has some sort of readily available battery inside, I would bet on it. Since I have a good size collection of multimeters, I have gotten so I put a label with a date on the ones I install batteries in. Most of them you can still use for measuring voltage without batteries.
RJSakowski
Feb 1, 2015
5,175
The analog VOM's only used a battery for measuring resistance. My Triplett VOM uses a D cell for the lower resistance3 scales and the 30 volt battery is only used on the R x 100K scale.
Back in the days when you still had to set dwell on a distributor, I would use my VOM. I could chuck the distributor in the lathe and connect the VOM resistance leads across the points. The meter was set on a resistance scale and the lathe turned on. The fraction of a full scale reading x 360/ no. of cylinders is the dwell. For example for V8 engine, a 6 volt reading on the 10 volt scale would be 6/10X360/8 or a dwell of 27º.
Superburban
Jan 2, 2016
1,330
See, you had a analog PWM controller, and did not even know it.
My ME 77-C/U's, take a 22.5V battery about the size of a 9 volt battery, only for the highest resistance scale, So not having that battery, only cuts out one function of the meter. Not worth the outrageous cost of the batteries. I have considered using a 9V battery, along with a Buck Boost converter to get the volts up to the 22.5V.
dpb
Oct 8, 2016
184
On the Beavis and Butthead end of this conversation, I was once a young marine, tasked with cleaning out a supply room. A large box of typical 9v batteries (green, of course) were plugged directly into one another, to make a new, single battery, somewhat longer than my forearm. When shorted with a couple wires... it was impressive.
RJSakowski
Feb 1, 2015
5,175
Great out of the box thinking!
AdBlock Detected
I've Disabled AdBlock
