- Nov 24, 2013
- 1,791
I use fluid film http://www.theruststore.com/Fluid-Film-C67.aspx
Middle.road - An old trick to prevent rust on tools in confined spaces such as storage cupboards, big toolboxes, and other compartment areas, is to leave an old-style filament globe on, in the compartment, full time.
The heat from the filament keeps the temperature up above dew point and totally eliminates rust on tools (provided you keep them lightly oiled, of course).
The only cure for your shop is some kind of modest heating on at all times when the air temperature drops below the dew point.
+1 about the slab. Just went out and moved some rubber backed carpet squares I have in front of a bench. Dampness underneath.
And guess which way the lot slopes...
I should have epoxied it before we moved in. Trying to paint it now would require some serious shuffling - shop is packed.
Shuffle to one side, paint, let dry, shuffle to other side - repeat. Sounds like a heck of a recipe.
All the walls and the ceiling are insulated. But how much you want to bet that there is no poly or any type of barrier.
I've got a 30" fan mounted up in one corner but I guess I'll have to consider a dehumidifier. Gads I hate the cost of running those.
A buddy whose in the HVAC biz mentioned putting in a heat pump system if he runs across a good used one.
My other shops here in TN were a basement, garage, garage, and then this garage. The other two were attached though.
And acids or corrosives I keep out in the back shed.
Pulled out my mill vise yesterday, it's been sitting in a milk crate oiled and wrapped in wax paper. Didn't work, took a hour or so to clean it up.
I have (3) cans of this on hand, been in my stock for years, I finally tried it on the vise. Wow - it does smell up a place.
View attachment 81798 I guess I'll start coating everything that's susceptible. Especially tools I don't use frequently. What a PITA.
Thanks,
_Dan
