- Mar 26, 2018
- 8,604
I didn't know it would do that??
I was using one of those anti-vibration blades I got from McMaster.
It was on the 14" Delta band saw. The sheet metal was perforated (had little holes) 16 gauge.
I cut about a 12" piece and discovered the missing teeth.
Going back to the drawing board I discovered there are blades for sheet metal. This blade is a 1/2" wide- 10-14 TPI for 1/4" to 1" steel, brass, aluminum etc..
I replaced it with a McMaster 1/2" wide .025" 14 TPI blade.
I will not be cutting perforated sheet metal anymore.
FYI
FYI
