author=baldric link=topic=3853.msg28245#msg28245 date=1317663946
I have decided to go for ER 25 collet system,as opposed to using the mt 3 system of holding the cutters. The reason why,is because to (break) the mt 3 taper, I have to loosen the draw bolt two turns then belt it with a hammer, I noticed the drawbar (nut ) is not screwed on but pinned.
and I thought I might sheer the pin one of these days, The other reason , is everytime I strike the drawbar theshock load goes onto the bottom bearing ...
Actually, it's the top bearing that would take the shock, but you're right, too much of a shock is a problem. If it takes more than a light tap or two to loosen the collet, then something is wrong. I have a similar problem with my Hauser 3BA Jig Boring machine, which has an MT2 spindle. You're supposed to be able to release the tool by turning the large knob on the drawbar but something has happened and some (but not all) tools will get stuck but good. Often I can't even knock it out with a drift (I support the end of the spindle when I'm using the drift so I don't risk the bearings). I'll be darned if I can see any problem with the spindle and I don't want to try reaming it. If I could find an MT2 lap I might give that a shot, but so far I'm just living with it.
My solution was to go the ER collet route as well. I have ER-32 and ER-25 chucks and collets but I find myself reaching for the ER-25 unless I need the extra capacity. The ER-25 chuck stays in the spindle most of the time. When I need to use a drill chuck or boring head I use a pair of Jacobs taper removal wedges (#6) to pop the chuck loose and that works great:
That trick only works when you have something in the spindle that has a shoulder on it so that you can get the wedges around the shank of the tool, between the back of the tool and the front of the spindle.
You don't need to remove an ER chuck to change collets. You use a spanner on the nut on the front of the chuck to loosen or remove the collet. If you've never used an ER collet chuck before, the collet snaps into the nut and then you thread the nut onto the chuck; don't make the rookie mistake of putting the collet in the chuck and then trying to tighten the nut or you'll damage something.
I got my ER chucks and collets from
CTC Tools. They have ER-25 chucks with MT3 drawbar shanks (M12 or 3/8-16 thread) for $17 and collets sets for $38. They used to offer inch collets, but they only seem to carry metric now but. That's OK since an ER collet will collapse to the next size below it, that is, a 7mm collet will hold anything from 6 to 7mm. You really have to chinch down on a 7mm collet to tighten up on a 1/4" end mill (6.34mm) but it works fine. CTC ships out of Hong Kong, but it's worth the wait.
[size=18pt]Cal[/size]
