- Apr 23, 2018
- 6,635
I have replaced many 6003 bearings, they are really common in Japanese transmissions and axles. They are always press-fit to the shaft, always. If a body has the right tools to accompany a hydraulic press, it's a safe and routine process. You must support the bearing's inner race, and if you can't, try making a better set of press tools, because it's fundamental to the process. Good (not 3rd world garbage) bearing press plates are worth their weight in gold. Press arbors and shells either purchased or made from pipe/tubing material will do the job even better. You need something close fitting to support with, and something well-suited to drive with. Without that stuff, a press is just... well, it's just another hammer to ruin your parts with.
