- Oct 10, 2018
- 543
So, I'm trying to resurrect an very old Dumore tool post grinder. Some previous owner has, I think, remade the spindle (aka quill) and thrown away some parts! I don't know for sure as I can't find a parts list that corresponds to the model I have. Mine was apparently designed for a "total loss oil" lubrication; not sealed bearings. There is a Gits oiler cap on the housing and an old Care & Operation (C&O) manual says to add a teaspoon (!) of oil each 8 hours of operation. I believe the idea is to continuously flush out any grinding debris from the bearings.
The spindle that was in the grinder when I got it is bent. I'm sure it is user-made rather than original. Below is a picture of the parts. As it stands, the spindle goes in the bearing and then fits into the housing tube. A cap threads on and bears against the outer bearing race only.
The C&O manual says that the grinder is "equipped with a specially designed internal preload arrangement" that "maintains the correct preload on the bearings, even though the spindle expands and contracts due to heat changes." There are no details, however, on that preload arrangement.
I tried contacting Dumore for any information they could provide but haven't received any response in the last two weeks.
To sum up, I think I should add preload to the bearings but I don't know how this was done originally.
AIUI, the preload is pushing the inner race one way and the outer race the opposite direction, right? So the balls in the bearing riding against sides of the race rather than in the valley. [1]
I'm guessing that I need some kind of flat spring washer. Maybe:
or
What size do I want? Does the spring press against the inner race, the outer race or both?
Thanks in advance,
Craig
[1] https://www.nationalprecision.com/library/articles/bearing-preload.php
McMaster-Carr
McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
www.mcmaster.com
or
McMaster-Carr
www.mcmaster.com
Thanks in advance,
Craig
