[4]
BELT SANDER REPAIR
[3]
[10] Like what you see?
BROCKWOOD
H-M Supporter - Gold Member
May 26, 2017
613
I have no idea of the correct place to post this repair of my ENCO 6 x 48" Belt Sander. When it arrived, nearly every part was dented & the main brace was broken into two parts. I was already aware that replacement parts from Grizzly can take 6 months. I really did not care to find out what hassle a warrantee claim with ENCO might be. The broken part, to my way of thinking is inferior. Instead, I made my own. The only tools needed were a band saw, rotary table & mill.20150802 002.jpg20151104 004.jpg20160315 001.jpg20160826 034.jpg20160826 039.jpg20160902 008.jpg
RandyM
H-M Supporter - Commercial Member
Staff member
Apr 12, 2011
2,358
:cheer::cheer::cheer:
You and I think alike. Well done.
Moper361
Active Member
Sep 15, 2017
277
Nice repair and your part is far superior to the nasty cast bracket supplied be assured yours won't break in a hurry .
brino
Jan 2, 2014
3,610
Easier to replace the part than deal with warranty returns.
Great upgrade to a new tool........too bad it was required!
-brino
kvt
Oct 21, 2014
2,072
Nice and a lot more sturdy than what came one it.
BROCKWOOD
May 26, 2017
613
On to the 2nd weakest link. Pics for now - very frustrated. 1st day not walking on a cane in 4 months - still injections & physical therapy are needed. So, I assess what the order I need to pick up where I left off should be & snap the tool rest while truing up a scraper. Aghhhhhhhh. Well, it won't be any different from the main support when I replace it: Stronger better & possibly even prettier! Might even have to add a dedicated circuit breaker - incase something else wedges up under it ;-)
brino
Jan 2, 2014
3,610
Sorry for the trouble your having to go thru (medical and otherwise!).
Looks like the machine was build from uncooked pasta!
-brino
MrWhoopee
Brass
Jan 20, 2018
710
I LIKE the table for the belt. Now I'll have to make one for my Craftsman.
BROCKWOOD
May 26, 2017
613
Thanks MrWhoopee. The fence / table is adjustable from a +10 to a -60 degrees. It's too oily to add paint. Trying to just get it done during a 60hr work week is good enough for now. Sticking to a theme of all the shop made replacement parts get painted red. I kept the belt adjustability from horizontal to vertical when making the main brace.
Finished for now.
BROCKWOOD
May 26, 2017
613
Well MrWhoopee, I appreciate your perspective. Yet, I am glad I took the table / fence down for paint. See, I kept the belt angle adjustable just as designed - only I used real steel for the main support & grade 8 bolts for assembly. Well, the belt carriage began to slip & lose it's angle. As designed (regardless of whose bolts were used), angle changes for the belt tilt required removing the disk table, disk & loosen off the belt pulley just to get at the bolt heads. This pinch bolt arrangement was replaced with T nuts on the back side that travel in the semi circle angle adjustment holes & studs. Now I can change the angle of the belt without taking anything apart!
Besides, the red paint actually draws attention away from the crappy sander & onto the parts I made. Ready to Rock again!
Z2V
H-M Platinum Supporter ($50)
May 10, 2017
755
Looks good @BROCKWOOD, I usually paint my stuff also.
Good to hear you are recovering well from back surgery. Hang in there.
MrWhoopee
Brass
Jan 20, 2018
710
I was actually being facetious, which doesn't always translate well in print. You have to do something to prevent rust. The red does indeed draw attention to those parts and is a nice contrast to the usual tool gray. Nice work all around.
Downwindtracker2
Sep 5, 2014
411
I'm not too impressed with the table on mine. Aluminum , a single support and very flimsy angle bracket.
BROCKWOOD
May 26, 2017
613
You may be up for modifications / improvements on yours too Downwindtracker2.
Downwindtracker2
Sep 5, 2014
411
Yes I just might. I first have to reach a certain stage of frustration, then I break down and fix it. I have looked at it more than a few times, but haven't seen any quick and easy. I have used it a fair bit to flatten the soles on wood working planes, one plane, one belt. Stanley and their green castings. Oddly enough, I saw a Delta on CL. I could almost afford., but the BusyBee, Canadian for Grizzly, was handier with it's exposed end roller. I worked for while in my youth in a machine shop, it was shocking how many parts were "machined" on a Delta 6x48/12"
BROCKWOOD
May 26, 2017
613
My Stanley planes are so old that I just use them as is to keep value. Let's see pics of your belt sander. I too am not impressed with the aluminum table for the disk sander. Come to think of it, the aluminum table is supposed to be usable on the belt as well. Nope, never even considered trying it. Too flimsy, as you stated. I rarely use the disk sander portion & suspect this is because of that aluminum table. How was this done, built or arranged on the old Delta of your youth Downwindtracker2?
Downwindtracker2
Sep 5, 2014
411
The only difference between mine and your belt sander, is that mine is painted dark green. It's a '90 something? Taiwanese. The Delta had proper trunions on both cast iron tables. Before the plant shut down, about 6 years ago, they bought a Chinese made Delta for the maintenance shop. I didn't get to use it much and it went too high at the auction. The machine shop Delta had more issues with tracking then my BusyBee.
Sometimes there is a germ of a good idea, just the execution is wanting.
My Stanley planes are mostly newer, Canadian Sweetharts from the 30s are preferred,, nothing of value except as users. I found a made in USA #4 from 1949, a great year personally , that I tuned by hand. It was after that one, I used the belt sander.
[5] [7]
