- Nov 16, 2012
- 5,596
Yes, a typo indeed. 40-60 HZ. This is self imposed as I'm a firm believer in using the gears as much as possible and only tweaking RPMs to suite a particular need. This (I feel) keeps the motor working in a decent torque range and does not place undue stress on the gear train.
The lathe and mill motors are 4 pole which have high-end RPMs of just under 1800 RPM. 2 Pole motors (usually used on surface grinders) will spin up to 3600.
Ray
Ray
I got this set-up on my wood lathe. Works off 110 volt, I like that.
Working pretty good, but don't know how the import motor will hold up?
http://dealerselectric.com/item.asp?cID=0&PID=6898
- - - Updated - - -
Did you mean 40-60 HZ?
- - - Updated - - -
Am thinking about going with the same set-up I have on the wood lathe, 1/2 hp is enough for a 10" logan right?
