- Feb 28, 2019
- 499
I've been a little reluctant to post questions related to desktop CNC as most people here are oriented to much bigger and more powerful equipment. I've found it pretty hard to get good advice even on other CNC specific sites.
But this is a great group of people with a heck of a lot of combined experience (who won't laugh at my machine ) so here goes.
The machine is a Nomad 3 for those who might know of it. Spindle power is 130W (yes watts) spindle speed is 9K to 24K RPM.
Work area is 8X8X3 it is very solidly built for it's size and it is accurate with feed rates that are more than fast enough - I've never run into feed rate limitations.
It is a great machine for what I mostly want to do - small accurate parts. This is the latest version and the spindle power is almost double of my previous machine, also a Nomad. Stuff that was a struggle is now a breeze and it will easily handle working with steel that was a stretch before.
What I have learned is that with this type of machine, you are always working on the edge chip load (bite) and available power/torque. The machine works great at high spindle speeds and feed rates taking cuts that approach the minimum chip load.
Then comes the drilling.
Maximum bit size is .125
The new machine has a minimum spindle speed of 9000K.
I've been using a "standard" relatively cheep HSS bit 118 point, no chisel. Mostly because they wear out quickly and I can resharpen them easily. Tried carbide but found they snap too easily in this sort of setup.
The issue is that for the spindle speed I have to work with, the plunge rate needs to be pretty high for the bit to be cutting more than rubbing. However the spindle doesn't have the power to maintain a high enough plunge rate. So you have to do excessive and small pecking to have any success on a deep hole (.5 deep in steel).
working cut parameters:
12000 RPM
2.8 IPM plunge
0.00023 feed per rev at initial RPM 0.00011 per cutting edge(!)
0.10 depth in a single peck
Independently measured spindle speed bogs down and drops to ~7 or 8 K RPM at bottom of "peck" so drops by roughly half.
My question here is:
Are the drill geometries that will work better in this kind of situation? Remember that I'm stuck using very high RPMs and low torque, and the bits are small.
Looking specifically for possibly trying different type/style of bit.
-Dave
12000 RPM
2.8 IPM plunge
-Dave
