- Feb 7, 2014
- 350
I am planning a spindle mounted ER40 chuck for my G0602. The thread on that spindle is 1 3/4-8. My little internal threading tools won't cut deep enough to do 8tpi, so I was looking at threading bars and inserts. Well, that frizzed up the short hair. IR16 tool holders that I found won't fit in my tool post, even if I could justify the cost of the bar and insert for a one-off.
I discovered the world of special taps last year. A quick Ebay search and I found a 1 3/4-8 NS tap for half of what the bar alone would have cost. Using a tap should also eliminate making a spindle copy to use as a thread gauge during single pointing.
So has anybody used taps this big? The plan is to use my spring center in the tail stock to get it started straight. But how much force is it going to take once the tap is fully engaged? Hopefully it won't spin in the chuck or need 2 feet of pipe on the wrench to turn it.
