- Sep 1, 2023
- Location
- Sherbrooke
I'm considering getting a used ZAY7045 mill with a 3phase 575v motor that I will need to replace, as I only have single phase 240v and 120v.
It is a gear head mill, with two gear knobs/levers (H, L) and (S1, S2, S3), for 6 combinations (see photo).
The motor plate has 2 numbers for RPM: 1730 amd 2850.
It's not clear if that means the motor has 2 wiring for each speed, or if the speed change is entirely driven by gears.
Needless to say, If the motor has 2 speed configuration, it will be harder to find a 3-phase motor that has the same specs.
Questions:
1) If I get a 3-phase motor with 1740 RPM, and a VFD, am I likely to get problems running it at 2850 RPM ?
2) How about a BLDC motor with a controller ? I see kits at reasonable price, with controllers, would like to get recommendations.
Questions:
I | II | |
L1 | 90 | 180 |
L2 | 200 | 400 |
L3 | 300 | 600 |
H1 | 550 | 1100 |
H2 | 960 | 1920 |
H3 | 1700 | 3400 |
