What a bummer, I was hand tapping an M5 threaded hole on my PM 833TV column benchtop mill to mount a bracket for my DRO and 1 of the 4 holes I snapped the tap off flush with the surface.
I see now way of using a traditional tap extractor, so I'm wonder, could I use a very small hole saw, large enough to go around the tap with no center, like the diamond drill bit?
It was a spiral tap, and I've tried a tap extractor but there's nothing to grab onto.
I want to drill it out plug it with a larger threaded plug and then an inner hole for the intended 5M tapped hole.
Pretty much broke off flush and slightly below the surface. I really don't want to move my holes.
