Brown and Sharp surface grinder - $550 Freeport NY
DavidR8
Staff member
H-M Platinum Supporter
Oct 16, 2019
6,574
Brown and Shop surface grinder. Three phase. Great working condition. Can load on your vehicle for free. Or deliver locally for a fee. 516-771-6492 Bus hrs, no texting.
@DavidR8 : You be the most avid permanent internet machinery searcher. And now - 3-phase does not bother you at all anymore!
Are you tempted?
Are you tempted?
If it wasn’t on the other side of the country I’d be all over it.
Note that it is all manual, no power feeds. If all you were doing is sharpening punches & dies, etc. it would be just the thing, not real good for long work.
Thanks, for my own education, can powerfeeds be had for these machines? (in the incredibly remote chance one ever became available locally)
I have seen a picture of a manual lathe with a readily available servomotor with encoder bolted onto a bracket on the end of the lead screw, controlled by a servo drive (like a VFD, but much better), and a network cable going to a little computer. If a machine has a handle that turns anything on a slide-way, it can become CNC in this fashion. One has to add the position feedback thing, but all the CNC guys on HM get up to that sort of thing.
Having all the big stuff with motors, and slideways, and mag-chuck and all arrive from a sweet deal, leaving one with a project to upgrade the manual aspect is what they love. If you need to go straight for a thing with all axis power feeds + DRO, you are unlikely to get it at anything like $550.
From the stuff you keep finding, I am guessing you are equipping Dave's Sooper Dooper Machining Man-Cave!
I think not. Personally, I would not have a surface grinder that did not have power feeds in both directions, manual feeds would be only practical for small and limited work, such as sharpening, which can be handled by a tool & cutter grinder, an much more versitile machine. A fully functional surface grinder like my 6 X 18 B&S Micromaster can be had for only a couple of thousand dollars, and it's predecessor, the #2, for perhaps half that.
Not so much equipping my own shop as just have good alerts set up. Well, if a surface grinder showed up locally I might not pass it up :D
@benmychree is right. You need at least the main axis to go back and forth under power, and another axis with a settable advance for each pass. Also, if it is so old that it really is "totally manual", the slide-ways may be worn, the main spindle may have some vibration, however small.
Let this one go! Your alerts will keep sounding off. You hung in there a very long time for your lathe, and I am sure there were some on the way that nearly had you going for them, and you did not regret what you grabbed in the end.
I really had no intention of going after this one as it is about 4800 kms away.
