Please find a scan of my manual.
It was wider than the scanner. Hope this works for you!
Should anyone find appropriate grease/lube I'd sure appreciate some help in identification and sourcing.
Please.
I need 2 oz of Mobilplex EP #23 lithium grease. I confirmed with Mobile that the new equivalent is Mobilux EP 023. The old stuff was supposedly calcium based, and is now just a powder in my Versatapper. As I recall Mobile said this is now typically used in Foodservice applications.
I found another website which suggest that the specs are "NLGI 000 EP semi-fluid grease has a worked penetration of 460 @ 25C, Timken OK Load of 40 lb, base oil viscosity cSt of 320 @ 40C, four ball wear of 0.40 mm and four ball weld load of 250 kg". Whatever that all means... And that modern equivalents might be "Chevron Multifak EP 000, Castrol HD Lithium 000 #5613, Conoco Dynalife L-EP 000 and others". I have not yet attempted to call the alternative manufactures.
Anybody have a couple of ounces they want to sell? Mine has been shelved pending finding an appropriate lube.
Daryl
MN
