- Aug 22, 2012
- 4,131
I didnt know where to post this so thought I would try here.
I have some plastic (HDPE) welding to do but not really enough to warrant buying a piece of equipment for $160+ that wont be used much.
I have a hot air gun (cheap, like me) and though that I could make a new nozzle for it to concentrate the air stream but have a fear this would constrict the flow so much the gun would overheat and blow the temperature fuse.
I thought that maybe if I cut a triangular shaped hole in the wide part of the nozzle before the restricted tip and cover it with a slide I could regulate the flow rate by using this as a by-pass valve thus keeping the original air flow through the gun hopefully preventing overheating of the element.
I have welded PE donkeys years ago so the actual process doesnt hold much mystique but wonder if the above would actually work in practice.
Thanks
Thanks
