Bullet Concentricity Tool
ndav8r
Aug 14, 2013
5
Hey Guys:
Just completed a "skeleton in my closet" project, that I started a long time ago. It is a Bullet Concentricity Tool, that long range shooter uses to align a bullet with it's case, so it makes perfect or near perfect contact with the rifle lands when fired. It eliminates unwanted harmonics in the rifle barrel. There are ones out there, but they have their flaws. I designed this one in AutoCAD. Why buy one for $100 when you can make one for a thousand!
It accommodates rifle bullets up to 50 Cal.
Here are Bullet tip Pilot Dies mounted on the base and on the plunger.
I mounted a more sensitive gage and a SPI micrometer push base to adjust bullet.
The frame is extra heavy frame that is adjustable to the bullet seating area.
The Bullet Case base seat into a 60 Degree pilot I can turn end for end for different case sizes.
How I use this tool, is that I place a bullet into the appropriate sized dies. I then push the left tail stock die with the bullet towards the right until the spring plunger protrudes about a 1/8 to 1/4". I then lock all levers. I adjust the pusher frame to the bullet seating area. I rotate the bullet by hand and find the high spot and mark bullet with a sharpie. I push the bullet with the micrometer noting the reading in case it needs a little more push. Other Manufactures of Concentricity Tools settle for about .003". This tool can get to about .0002", but it does take a little time.
Well, off to my next Skeleton of my Closet!
NDAV8R
ndav8r, a couple of year age I made one very similar to yours, but yours is a work of art and looks first class. Great job.
Hey Guys:
I love it! <vbg> Well done. Pretty tool, and it looks like it works well. Kudos.
Isn't that kinda hard on the micrometer base, or was that particular barrel/thimble built for it? (Precision tool abuse alarm!)
60yrs ago , when we were serious abt fixed ammo, , we bored straight line bullet seaters for specific cartridges ..bullets were seated in a slip fit bored cylinder integral & concentric w/ the base holding the case ......not sufficient accuracy ????????????
in scheutzen matches we used a bullet seater to push each bullet into the rifling an identical amt ...used w/out sizing , in order cast , & w/ a single case reprimed /wad on end retaining powder .& orientation marked
best wishes
doc
It don't take a lot of effort to move the bullet, especially the longer case/bullets because of the leverage. I do like the micrometer reference though for correcting. I picked up the base on EEKbay for about $15, to see if it would work out for me. so far I ran about 50 or so rounds through it in 22-250 & 7mm, with no failure yet. I'll let you know if any failures occur, so I'll keep my "stay-out-of-jail" card in case the Precision Tool Police comes knockin!!
Ndav8r
Beautiful job!!! I see you were able to use a scope mount base on this project. A good gun part is a terrible thing to waste. :)
