I've got an offer out that the sellers accepted although nothings been exchanged for a Harrison 330 s alpha with fanuc control. Dude got it from his CNC repair father so its not powered but none of them out here in texas are. I wanted something with a turret but I also need the bed length. Was going to use gang tooling for a bit but I've seen hydraulic 4 change tool posts used if I bought it. Other issue is its 480 which I'm not going to have so I'd have to rewire or replace the motor & starter heaters.
All of that is manageable but what I'm trying to figure out is if this is going to be worth buying down here and driving 30 hours north when I get out of this state coming up in a couple months. I liked this machine specifically because I've read it weighs 1200kg (although my source is slightly suspect) but there are other machines up there although much less of an inventory like 1 or 2 shows up every month. They're in the prohibitive weight range of 5 tons and above which I ain't gonna be able to move myself and I'll need a rigger and my experience with them so far has been garbage. Those machines start at 20 grand when my current deal is 6k.
I've done a lot of goofy moving by myself though. I've got a Bridgeport type machine I had little issue moving so far.
Plan was to get a 26 footer box truck which is rater for 8 tons but I feel like I'd be pushing it with my 1600lb mill, 1/4 ton lathe and 1 1/4 ton cnc lathe plus my house crap. I've got an oracle prediction of shredded tires in my future
