- Dec 13, 2012
- 466
Thanks Gary. For the same reason you mentioned, I won't be using the MT5 center. With my dog plate the MT5 center sticks out way to far for my liking. I would imagine using the faceplate as a dog plate it would stick out even more. I ordered a bearing steel import center from Enco that was on sale & applied a 15% discount to it. What I received was a Bison center which was a nice surprise, it would be a shame to cut this sucker down. I'll just store it away for now. But anyway, I won't worry about it & will stick with using the sleeve & a MT3 center (also got a Bison to replace the one that came with the lathe).
I can't imagine them using a drill bit to bore the spindle but who knows. I wonder if anyone has actually tried to bore the spindle on these 12x36 lathes. Looking through my spindle it's not bored perfectly through. Aside from the larger bore towards the front, my spindle is slighty bigger on the threaded end just before the threads about 3" deep. I measured the bore about 6" deep from the threaded end.
In regards to the TS, the stock set screws are junk. They are so loose. I've been meaning to order replacements on the next Mcmaster ordered but recently a friend did the same & sent me pair of replacements since they come in a pack of ten. I never stripped mine yet but man do the replacements feel so much more assuring.
Your lathe is different in other ways too if I remember. Carriage stop away from the cross slide and a different threading or speed chart?
